2.3 throttle body ???
dangerranger78
coker creek TN
2.3/2.5
hey guys i have an 86 2.3 4x4 and im starting to try to get a little more oomph out of it. i plan on an air intake pretty soon but on the 86 the IAC is located on the air box. Can i swap the trottle body off a newer model with the IAC on the TB and not on the air box? :icon_confused:
dangerranger78
coker creek TN
2.3/2.5
ok guess ill go to the junk yard and do some measuring and plug checking.
scotts90ranger
4,458
Dayton Oregon
2.3 Turbo
I haven't seen one with the IAC on the air box, but I imagine it shouldn't be a problem assuming it's the same actuator
dangerranger78
coker creek TN
2.3/2.5
thanks i think its a mid 80's thing. i ve seen 88-90ish models on the TB. ill look around the junkyard and narrow it down a little.
88ranger89camaro
Firefighter
Squaw Valley, CA
2.3
88 is going to have it on the box too ....... you can port your box to get more air in it and put in a K&N would give you good air flow with minimal mods, i used a dremel to cut another air inlet below the filter so it still sucks filtered air, just an extra hole to get more air from
dangerranger78
coker creek TN
2.3/2.5
thats a pretty good idea. did the throttle cable mod. made a huge drivability improvement. now looking for a little power up grade. nothing huge but my 2.5 is worlds ahead of my 86' 2.3. just needs a little help.
88ranger89camaro
Firefighter
Squaw Valley, CA
2.3
What's the throttle cable mod I haven't seen that one on here
Heavyfire14
19
imperial valley
FORD
2.9L
^^ zip ties on the throttle cable up by the pedal
chilsam
chillicothe il
91 branger
300 six
Yes!
I swapped a 2.3 from a 87 mustang into my son's 87 all I had to do was extend the wire from where I cut the the plug off ran it in with the power wires then spliced plug back on and am running a RE WORKS airfilter right off the throttle body with 94 shorty header and plugged EGR:icon_welder:.RUNS GREAT and really cleaned up the engine compartment.
