chewy012
- Jan 31, 2016
- Reaction score
- 1
- Location
- Colorado Springs, CO
- Make / Model
- Ford
- Engine Size
- 4.0 OHV
- Manual
Just put a CB in the ranger. Mounted it to the bed tool box, which is bolted to the bed, which is bolted to the frame.... Which is bolted to the battery.
Is that a good enough ground? Should I run a wire straight to frame?
The antenna is only a 22", but it sits above the cab line by 6-8" in the center of the truck and clears the radio antenna by an inch.
Does it need to be raised?
Sent from my XT1254 using Tapatalk
