Oxnard Ranger
- Feb 3, 2009
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
My newly purchased 01 Ranger "Check Gage" light came on? What does that mean?
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Yes, I misread the main post. My bad.an OBDII scanner is an OBDII scanner. they will all give you the exact same codes and you can only pull codes from an OBDII vehicle with a scanner intended for an OBDII vehicle (unless you know what your doing). its about as foolproof as it gets.
but a "check gauge" light isnt a "check engine" light. there are no trouble codes associated with the former. it means simply to check your gauges.
