By: Chris Emmons
remove brake hardware
Remove the brake caliper/hardware, then the nuts/washers etc, that hold the rotor on.
parts
You should now have a similar sized pile of parts.
spindle
Now, the fun part! Bang on the spindle with a wooden block, and a BIG hammer.
Don’t use a hammer directly on the spindle!
Use a star pattern and wedge a hard chisel in between for leverage once you get it moving.
spindle removed
This is what all your hard work will get you!
The spindle is now gone, and you can pull the axle shaft right out.
On the passenger side, you need to remove the clamp on the axle boot. Clean the bore once the axle is out.
spindle removed
The spindle will be really corroded. Clean it and smooth out any burrs you may have made in taking it apart.
Now is a good time to inspect the little roller bearings.
check bearings
Closer look inside says, “REPLACE ME!” It’s worth it to do this now, cause its cheap.
Apply anti-seize to the back of the spindle and the bore on the knuckle (AFTER you do the joints!). This will make the spindle come off easier later.
axle boot
This is the boot that needs to be released from the inner axle u-joint.
passenger side axle shaft
Passenger Side (long) shaft.
knuckle bore
This is a close up of the bore in the knuckle. You need to remove the upper and lower bolt attaching the ball joint.
Now you need to use a pickle fork for the ball joint, or a lot of hammering. Take your pick.
knuckle removed
WOW! Where’s the tire go!
ball joint tool
Go to www.harborfreight.com and get one of these. You can also rent them at parts stores.
Follow the directions, and it’s pretty easy.
You start with the lower one. Set the receiver cup to let the press push the joint out.
ball joint took on knuckle
another view
remove ball joint
do the same with the upper, running the screw through the hole left by the lower one.
install ball joint
Installation is similar to removal, but you use a smaller cup to press the new joint in.
The lead screw is against a cup that is not visible.
install lower ball joint
With the upper in place, and the clip installed (if applicable), Install the lower joint.
arrangement
The same arrangement of the press is used.
new ball joints installed
The fruits of your labor
install knuckle
Install the knuckle and torque to specs. Be careful to align the axle joints on the passenger side.
phase
You want the joints to be in “phase” with each other, so they don’t bind and break. (they do anyway!)
install axle
I like to square the top of the inner joint and sight down the axle to align it while installing the passenger axle.
Grease the joints, and have your truck aligned. The camber will be off if the joints were worn.
reinstall remaining parts
Remember this stuff? Well, put it back where you found it!
About The Author
