i recently put a 302 and a zf 5 spd in my ranger with a new master cylinder, slave cylinder, clutch line, and clutch. When i go forward and then try to back up it doesnt seem to want to go all the way into reverse then when i let the clutch out in grinds, but if i double clutch it then goes in fine, does this mean there is still air in the clutch line or master cylinder or is the reverse synchronizer bad, its a junkyard tranny, but i just thought it was weird to have a reverse synchro go out seeing as how it is the least used gear. I bench bled the clutch master cylinder before install, then did the bleeder on the slave cylinder prolly 5 times??????????????????
