- Sep 7, 2013
- Age
- 56
- CA
- 2.3 (4 Cylinder)
I've been trying to fix the chattering/marbling type noise in my 2.3L for a while now. It sounded like valve train noise. My oil pressure was good. I installed new Ford lifters and followers and still had the noise. I checked the oil pick up screen and it was clean. I installed a new oil pump and a New cylinder head with all new or reconditioned parts. I still have the same noise. I hear it at idle with the engine warmed up. It seemed to be under the valve cover, now I've noticed it's loud at the passenger side wheel well area. I can't pin point were it's loudest with a stethoscope, I can hear it, It just sounds like it transmitting. All of the lifters in the new head seemed to be pumped up. With all of the parts I've replace I'm just thinking maybe it's not in the valve train. Then I found this at youfixcars.com =
A wrist pin knock has a unique sound. This sound will be different depending on how many wrist pins are making noise. If all the wrist pins are loose this will sound like an overwhelming rattling inside the engine.This sound is described as a double knock, because it will cause a noise at the top of the piston travel and when the piston changes direction it will make another noise. This noise is most notable when the engine is idling and the engine is also hot.
This sounds like it could be the problem. What do you guys think ? I order new pistons, pins, rings and bearings. Has anyone seen this in a 2.3L or any other engine ? I did read about marbling noises at idle in 4.0Ls caused by wrist pins.
This will just be a lot of work for me and and don't want to waste more time and money and still have the same noise. The engine has 132K miles on thw 1997 2.3L.
