woooo look
m8r8j
hey looking to get a ranger. is there only one 5 speed manual transmission? how reliable is it 1-10 10 being BULLET PROOF??
how reliable is the 4wd system? should i just get a 2wd?
t-case?
im looking for a reliable daily driver @ about 5 thousand dollars.
2.0 vs 4.0???
so im guessing the ranger 5speed manual is a pretty damn reliable transmission??? my explorers auto 5r55w exploded on me so im a little skeptical.
reading up on it, correct me if im wrong, but since 93 til present fords been putting only one 5 speed in the rangers and its called the mazda m5od-r1. im going to research this tranny more
edit: some 4.0's came with the m5od-r2 or also called the m5od-r1hd which had the same internal pars just with lower gears until 4th.
how are the 2.3 and 2.5 liter 4 cylander motors?
The M5OD-R1 is the most strongest and most reliable transmission to ever come in rangers.
The M5OD-R2 is a very similar transmission that was used in F150s and F250s.
the M5OD-R1HD is nearly identical to the regular R1, but is assumed to have some slightly upgraded internals. How these are upgraded I dont know however.
Ive got a 97 with the 2.3, stick, and 162000. both have served me well. ive had it since high school and i dont take it easy so in my opinion they are both good. like everything ive had problems but of the parts i replace most are original so its withstood well. one thing is that the trans uses atf instead of gear oil. hope this helps
2.0 = painfully slow
2.3 = slow, but workable for a daily driver. Also nearly indestructable, even making way more power than they should (turbocharged).
2.5 = slightly faster than a 2.3
Note: 2.0, 2.3, and 2.5 are all the same motor with different bore/stroke combos.
2.3 duratech (2001.5+) = Pretty zippy I hear
2.8 = Lots of upper end problems and wonderful 80's carb+computer technology but the biggest motor you could get in the beginning.
2.9 = Fuel injected version of the 2.8, has a bad history of cracked heads and the failed cam bearings causing lost oil pressure. Other than that people still swear by them
3.0 = Nearly indestructable like a 2.3, but kind of gutless in the lower RPM's. People often complain they don't belong in a truck. Not a big deal with the right rear end gears.
4.0 OHV = Loads of low end torque and can really snap a 2wd ranger around pretty quick and in a 4wd they are more than adequate. In an explorer they are quite a bit slower but still adequate. Plenty of cracked heads though but it usually only happens to trucks that had a degraded cooling system
4.0 SOHC = Same torque as a OHV but with 50 more HP. They would be quicker, but about the time these came along the rangers started getting a bit heavier and Ford would only put them in the heavy 4x4 and/or supercab trucks. They're also hard on gas, with mileage not much better than a 4.6 F-150. Other than that they've suffered from some timing chain tensioner issues that are expensive to fix.
As long as you get a manual t-case you should be fine. The BW1354 comes in both electric and manual shift and from my experience, it's a great case but electric shift just sucks. It takes my electric about 3 minutes to engage anymore.
my brother was pulled over in my old ranger at 119mph with a 2.3.. i never had any problems at all out of mine and it was the quickest ranger ive owned.. its all about gears
what rear axles come in the rangers?
wow you shouldnt have showed me that cause ive been browsing it for like 2 hours now
t-case?
2.0 vs 4.0???
to answer you questions...the transmission was covered by other folksas well as the t-case.
4wheeld drive is good unless it has those darn vacuum hubs. if that is the case, dont sweat it and replace them with manual hubs(i did that just a few weeks ago..good stuff) all the motors are reliable in my opinion as long as you keep up with them.
my 3.0 has done me well, wish it had a little more a$$ to it but gets around just fine. my old friend has a 3.0 2wd and he gets up into the high 20's in mpg whereas i hit only about 18 mpg average.
