wildbill23c
TRS Banner 2012-2015
Ham Radio Operator
- Aug 22, 2012
- Southwestern Idaho
- 2.9 V6
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 215/70-R14
- My credo
- 19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
I see why you need those now. So like you said, a 15 amp fuse would work right?
15amp max, and since you are using LED bulbs you could probably get by with a smaller size fuse like a 5 or 10amp even. The lower the amp size fuse, the faster it would react in an overload situation. I'd rather replace a fuse at 15 cents than a vehicle at $1,000+. I'd get the things wired up then try a 5amp fuse and if its not large enough the fuse will blow, then go to a 10 amp, but I wouldn't go any larger than a 15 amp for this lighting application due to the lights will not draw that much current. Look on the package when you buy them it should also tell you the amperage.
