- Feb 23, 2020
- Raleigh NC
- 2.3 (4 Cylinder)
1993, MT, 2WD
Need some help from the guys that have added the dual speed electric Volvo fan to your Ranger. How do you wire the fan to turn on when the A/C is turned on?
Right now I have it set to turn on with a temp sensor in the upper radiator hose. When the A/C is on before the truck to warm enough, the condenser will get too hot and the high pressure A/C hose will get too hot and push all the freon out.
My thought is that I wire one speed to the temp sensor in the upper radiator hose and then second speed fan to the A/C switch. You think this will work?
