wipper acting up keys acc?
Spowerback
Banned
--- Banned ---
California
I guys. What problem, if my Wipper function when ignition key to the accessory position. ALL HELP WOULD APPRECIATE
That was my initial thought too, but I'm trying to be less of a grammar nazi.
ignition key on to the position. time every works. hai!
Simple inderstand you can't?
I think the wipers are turning on when he turns his key to the accessory position.
Wrong that out time I could be.
Yoda......If the wipers are coming on when you turn the key to acc and nothing has been done to the truck wiring, then take of the steering column cover and start checking out the wiring. Loose connectors. frayed wires shorting out, etc...
I could turn on and off my radio by flashing my brights. The ignition switch connector was loose. Tightened it up and the problems went away.
So that's what he meant. I was wondering what a "wipper" was.
I thought some BDSM dominatrix came around and hit him with a rope of tightly bound leather straps every time he turned the key to ACC.
But that wouldn't necessarily be a problem then would it? Hell, if it were my truck doing that I think I would be tempted to spend some time in there before selling it to the highest bidder.
Spower, in all seriousness, Check your column wiring and connectors. And if you happen to be a Croatian who has better second language skills then I do, please accept my apologies for having a little fun with your post.
