Windshield washer pump...
Mark_88
Ontario, Canada
Love Thy Neighbor
So my upgraded windshield washer/coolant overflow tank had to be replaced...the washer pump quit on me...tested the connector and it had voltage to it so I figured the pump was wonky.
I could not find one like I had out of an older F150 so I had to look around the junkyard...found one in a newer F150 but they separated the coolant overflow at some point and had to make do...
I installed the singular washer fluid/pump and cut the old one in half to use the old coolant overflow...
The two wires to the pump were the same so I just connected them up and tested it (before I actually started the whole process) and it worked.
I can now squirt the guy behind me in the eyes if I angle the nozzles up just a bit...:)
