2.3L ('02-'11) will not idle
this is the intake flapper control gizmo, 2002 2.3 manual on a stand.
there is an actuating rod that runs thru the intake, it's bushings wear out and rattle.
37815
I would be more concerned with the variance between cylinders than actual numbers.
as long as the oil consumption is good the rings are OK.
a vacuum gauge will tell you if a valve is leaking, reading will jump all over the scale.
cyn #1 240
cyn #2 185
cyn #3 200
cyn #4 205
put in new plugs, same issue/no change. moving on the fuel injectors/fuel pump
Those sure are some odd pressure numbers.... either your guage is horrible or you need to be running 120 octane jet fuel.
