Will my front axle break????????
How to put 35s on a stock ranger
  • Total voters
    23
Rear jeep warn hubs and weld the caps dont use the full circle clip, i've wore the crap out of an axle shaft from the u-joint cap spinning so much with full circle clips.
That means your shaft's already wore out. If anything, tack the cap to keep it from spinning and use the snap ring to retain it. Fully welding the cap makes it a pain to remove, and can also change the properties of the yoke material, weakening it.
