Izzy
- Jan 15, 2008
Hi,
I recently purchased a '94 B4000. The seller told me it had a bent crank otherwise all else was fine ... when looking over the battery was dead, so I didn't check anything, just towed the truck home.
This weekend I charged up the battery and turned the key ... to my surprise the motor cranks quite nicely, but would not start. I would have expected a motor with a bent crank to either not turn or make some kind of noise. But being a novice (but trying to learn) I thought I'd ask you all ... would a 4.0 motor with a supposed bent crankshaft crank like a normal engine?
BTW, I did check for spark by putting a spark tester in line with one of the sparg plug cables ... no spark.
TIA
-Izzy
TIA
-Izzy
