Will 35's fit
purecountry
OK I HAVE 31'S ON IT NOW AND I AM THINKING WITH A 3'' BODY LIFT AND SOME FENDER TRIMMING I SHOULD BE ABLE TO. WHAT DO YOU GUYS THINK.
It should, but it will be a close fit.
Nice truck!
Yes they will but you may have to cut a little more front fenders than what I did. I put a 3" body lift on my 89 Ranger 4x4 and cut the rear fenders where they start to flair out. I only had to trim a little off the back of the front fenders, however I also have 1" spacers under my coils. Just watch how wide of tires you put under it. Ive got 12.5's under the front with some rubbing at full turn. However, I did put 14.5's under the rear and they rubbed the leafs, so I made some 1.25" spacers. Other than that I have no problems with flexing em. Just make sure you double check your fender cuts for any sharp edges or small pieces that could eat a sidewall (I learned this the hardway after not checking my buddies cut who was helping me with it, ate a 14" gash in a sidewall first time out) Hope this helps ya.
With a lot of cutting they will fit.:icon_twisted:
-PlumCrazy
EDIT: Be sure to gear down too.:icon_thumby:
with the stock 28 and 7.5 in the rear i'd be weary of 35's. heard of alot of ppl breaking axle's and such with 33's. let alone 35's. but i think it will be determined by how you use your truck.
i'm on 33's now with that setup, and its tough as ever. haven't broken anything and i beat on it.
goodluck!
