Will 35inch tires clear?
j.apps
Wisconsin
I have a 99 ford ranger, i have a 3 inch body lift on it, with the torsion bars cranked about 2 inches and two inch blocks in the back. I am wondering if im going to be able 35 12.50 r15's. Right now i have 33 12.50 r15's that clear with no problem.
I have a 99 and I run 35x12.50 with 3" BL and cranked torsions...but I have 5inch blocks to replace factory ~2" block. Also I cut 4" of clearance out of my fenders. I did that after I put the 35s on as at full flex f/r they would hit the top of the fender wells. But a heavily backspaced wheel may alleviate some of that rub, as I still rub on the torsion bars and sway bar mount but I cut that mount off as I hate sway bars. Since, I cut the fenders and added the blocks I could probably clear a 38/39 tire but front axle wouldnt appreciate it.
