stingray
- Sep 6, 2009
- Automatic
ok guys, i have a 2001 ranger 2wd 3.0 litre w/front abs. the problem i'm having is when i checked the front brakes i found that the front pads were about 1'' taller than the rotor causing the pads to have a deep wear groove in them and the 1'' of the top of the pad being above the rotor. is this normal wear or should the pad wear evenly from the top to the bottom.i have never seen this before,is this something that i should be worried about?
