muddin76
- Feb 16, 2008
- Age
- 49
I have a 96 ranger supercab 4x4. Warn locking hubs, I jacked up the front end and locked the hubs, everything locks and turns, when I shift to 4 high and turn the tire on the driver side , transfer case is locked and I cant turn it. However, if I give a little force by hand the front tire will free. The axle or shaft from the tire to the gear box on the fornt spins with the tire so I know it is still locked in. But it is free from the transfer case now. So it seems that the front axle comes free when under pressure.Also the front drive shaft to the transfer case is still locked. I hear no grinding, no shimmy, drives great, even when in 4hi & 4lo, front end just breaks free when under pressure. I hope someone can shine the light on this for me, I have some mechanical background, just never had to tear into an axle. Would low fluid cause this, (lack of pressure) ? Could the axle end be spun and not holding under pressure ? is a pin in there that may have sheared off?
