OilPatch197
- Sep 23, 2007
- Age
- 96
- Automatic
Yeah, why couldn't you just have a belt driven pump like the power steering pump for the transmission?
Why is an engine oil pump inside the engine? Same as a tranny?
Its just a matter of simple engineering. Make it simplier, less things to go wrong.
Why can't a power steering pump be in the steering box?
Why can't a alternator be in the battery?
Why can't the water pump be in the radiator?
Why is the fuel pump in the fuel tank?
It's hard to hook up the alternator to the battery driveshaft. And that radiator bearing gets in the way.
The fuel pump is in the tank because you can't get vapor lock that way. I sure hope you don't miss that....
And on GM, they use the P/S pump as a means to deliever power brakes.
