Muddytruckn
- Aug 4, 2014
I've looked all over for this seemingly simple answer. My drive gear is worn out in my transfer case (BW1350). It's mounted in a 1988 BII behind a FM146 & 2.9..
The stock gear is red/burgundy, 6 tooth. When it does decide to read, it's way low but most of the time it doesn't read anyways so I plan to fix that. I have 2 different driven gears to choose from 18 & 19 tooth & I plan on moving to a 7 tooth drive gear so my speedo reads correct. Sounds simple enough until I started trying to find a replacement & ran across two separate Ebay listings:
#1 - "7 tooth narrow steel sleeve 0.779" wide OEM Ford speedometer Drive gear for a transfer case in an Explorer, compact SUV, or Bronco II. This fits the 1.147" shaft ."
#2 - "7 tooth wide steel sleeve 1.5" wide OEM Ford speedometer Drive gear for a transfer case in an Explorer, compact SUV, or Bronco II. This fits the 1.147" shaft"
They appear to be the same but one is .779" wide & the other is 1.5" wide. I really don't want to tear mine apart until I have the replacement in hand since this is my driver, but if I have to I will. Does anyone know for sure which drive gear I need? Wide or narrow?
