Which Cylinder Head To Use
dasophoto
Austin, TX
I am building a 2.3l motor for my 1949 Willys CJ3-A and have two different heads for the motor. One came off of a 1985 Ranger and the other off of a 1996 Ranger. Is one capable of producing more low end power than the other? The block is an 85 Ranger 2.3l. I'm a total newbie at motor work and figure this is the best place to ask. Thanks for your help!
Supposedly the older heads are more prone to cracking. They have 4 spark plugs (88 and older.) '89 up has 8 plugs. There are also different shapes of intake ports so you have to match the head to the intake you are going to use.
Having owned both I feel that the '96 made slightly more power than my '88, even with 250k on it vs the 30k on the '88 engine that was rebuilt and bored 30 over... but it was marginal.
Really just depends on what intake and fuel supply you want to run.
What you have is a 2.3l Lima engine, nicknamed the Pinto engine because it was first used in 1974 Ford Pinto
Very reliable engine, built like a tank, it has been used in many industrial applications, along with Ford cars and trucks
Mustangs used them for many years
So Good choice for Jeep build
The torque you have is set by the Cam you use, car cams have less torque but more horse power, truck cams have more torque but less horse power.
And you can use custom cam for even more torque
If you want to stick with distributor and carburetor, and NO computer, then that will decide the head you will use
So you will use the 1985 head
If you want to go distributorless and Fuel injected then you will sell the 1985 engine, w/1985 head, and buy a 1989-1994 2.3l with wiring and computer, and may be with a cracked head so you can get a deal and use your 1996 head on it
With the 1985 you can use a 2.3l Duraspark distributor with a Chevy HEI module, yes Chevy, lol, for a very reliable a strong spark system, 1 wire hook up, 12volts, 2nd wire if you want a Tachometer
Carburetors do have draw backs for 4X4s especially when you do steep angles, the float bowls are the problem
I agree on the dual-plug head having cracking issues, I ended up having to get a replacement head from autozone after not being able to get a junkyard head that wasn’t cracked. The right differential ratio makes all the difference with a 2.3 it’s a easy engine to work on though and a “non-interference “ motor, so if you break a timing belt you won’t bend valves or poke holes in pistons, just line up the timing marks put a new belt on and go.
I'm going to stick with the distributor and the carburetor. I'm using the Autolite 2100 carb which has some solid offroad modifications. If I built a custom intake I could still mount the 96 head on the 85 motor, correct? the 96 seems like a more efficient head with the roller design on the valves. Is that a correct assumption?
The roller cam followers reduce friction, which is a good thing. You may be able to get a 'carburetor' intake from Esslinger or Racer Walsh as the Lima was used in some dirt track racing(I think) and there are performance parts available.
A cheaper solution if you can find one is the 1974 two barrel intake used on the Pinto & Mustang II. It came with a Holley-Weber progressive which definitely resembles the 2100. Problem with them all is finding the oval, round, or flat-bottom intake ports to match the ports on the cylinder head. And the fact most old ones are now crushed.
The 74 had a points ignition(hens teeth, anyone?) and was the only model year with points.
The engine was used in a LOT of industrial applications, so other carbureted and LP gas versions are out there.
Fitting an OHC under the hood, with a air cleaner mounted up top may point to a relocated air cleaner. I don't have measurements.
tom
Those 2100/2150 carbs would be sweet on a 2.3. A couple of local guys make custom intakes and ran them on Toyota 20R/22R engines. They were sooo much happier with them than the Webers they ran before. IMO they are the best offroad carburetor you can get.
There was a marine use of this engine too. I worked at a boat dealership in the late 80’s/early 90’s and saw a few Starcraft boats with this engine and a omc cobra stern drive. They were carberated and had a point distributor.
You'll have to make your own intake or an adaptor to run a carb on the '96 head plus you'll have those extra 4 spark plug holes if you're gonna run a distributor. The roller camshaft will work in the '85 head but I think they changed the roller followers in '95-'96. They went to smaller valve stems so you'd have to open up the valve side of the follower or get the older style. Does the '85 head have D-shaped intake ports or round ports? Late '85 was the changeover from round port carb to D-port EFI. The round port doesn't really have a lot of options for intakes. There are lots of options for carbed D-port intakes though. E1ZE intakes, Esslinger, OMC, and efi lower with a carb adaptor. I'd keep it all '80s and 4-plug myself.
Yeah I've about decided to keep the 85 head. It is a d-port. I was thinking about just adapting the lower efi intake to begin with...just because I have it. And then maybe going to the Cobra or the esslinger when I have a little more funds to drop. Thanks for the input Daniel! I've made some progress on the motor, I reamed and honed it, cleaned it up and got it painted.
I've run the E1 intake and now I'm running the Esslinger. I have the efi lower and adaptor but I haven't tried it yet. Some people say it kills bottom end, some say it helps, I don't know. I do know I'm satisfied with the Essy except for routing of the throttle cable because the carb sets sideways. You probably have a linkage throttle and that would really be a pain to hook up.
What adapter are you planning on using on the efi lower? I havent been able to find one for the motorcraft 2100.
I think the one I have is from Powerbyace. I picked it up used though. Autolite/Motorcraft 2100&2150 use the same mounting pattern as 2300 series Holley carbs. I do have to use a thick Ford carb gasket though with the MC. I usually tell them I need a carb to spacer gasket for a 1982 F150 with a 302. lol
This is when I first test fit everything. I've since plugged the injector holes and plugged all the sensor holes on the efi manifold. I'm gonna switch to this 300cfm Holley with a smaller power valve to see if it helps going from off idle to wide open throttle.
Yeah I figured I would need to plug all the same things. What about the radiator fluid port on the flange...I know some guys block that off, did you? Not sure if the air being a little warm is bad, maybe its good if you live in a real cold climate?
