Where to buy hydraulic clutch line fitting by itself?
misterW
At one point I had acquired a hydraulic clutch line that was made of braided flexible steel instead of the hard plastic line that usually comes with it. It made dealing with any clutch issues so much easier. It didn't catch on things when installing or removing, it was easier to bleed because it didn't have that stupid bend in it, etc. I have thought about putting one together myself -- just buying a flexible line from Summit or some other place --but don't know where I could get the quick disconnect fitting that goes from clutch line to slave cylinder. Anybody know where I could buy that fitting without the line attached?
Get a job at The company that makes them for Ford and put one in your pocket before you leave at the end of the day.
(Just kidding)
I've salvaged end fittings from air and water lines. You could probably do the same with hydraulic fittings.
