So, If you're reading this you're probably wondering which wire goes where on your little truck... I have the answer for you IF you have the 2.3L Split Coil distributorLESS ignition system in your little ranger.
Green - Bottom right of ICM(Ignition Control Module)
White - Cluster Dimmer Switch
Black - Unpainted BODY Ground
Red - Radio slot on your Fuse Panel
So, if you don't have the diagram or cover for your fuse panel, email/message me and I'll gladly send you a scan with the highlighted wires needed for your install. Your welcome guys, this took me almost a week to figure out, I hope it saves you some time.
