- Sep 13, 2020
- Texas
- 4.0 V6
- Automatic
- Total Lift
- Leveled out +1 inch at the front
- Tire Size
- 33 x 12.5 x R15 Baja Boss MT
- My credo
- For every door that closes another one opens for you to lead others always when you least expect it!
Momo,
The best way to test any circuit in a vehicle of the age we are discussing for a battery being drawn down is to first disconnect the battery alone and watch it over night. Don't leave the meter connected. Often the battery will have a shorted cell and draw itself down disconnected. Once that test, issue has ruled out a good or bad battery, you can proceed.....
On your meter, leave the black wire where it is (COM) on your digital multimeter (DMM), and plug in the red probe to (10A) hole. Disconnect your battery's negative cable. Connect each meter probe (doesn't matter which wire goes where), one probe to the neg battery post & the other one to the neg cable you just took off. Connect them well enough to not have any intermittent connections. DON'T start the motor, Don't turn anything on. The meter is now showing your parasitic draw. If you have any. If you see something, it will be for sure the dome (door) light if the door is open. I would pull that light and get past that issue first. Then you can start pulling fuses one at a time.
If it shows any value displayed, then you have something still connected and potentially drawing down the battery. Start unplugging the fuses if a value is displayed. One at a time. Remember, do not turn ANYTHING on. You will likely blow the internal 10A fuse inside your meter. Plus the probe wires will not pass 10A for very long. Pull one fuse at a time while taking a video, pictures for a record of what fuse goes where. Do not replace the fuses with the battery's negative cable replaced and connected, or when the meter still connected during this test. Funny things sometimes happen like the ECM restarting. Stuff restarts when the key is in the OFF position. Do yourself a favor and replace the fuses one at a time with the battery/ meter fully disconnected. Pull one of the meter probe wires off each time to replace each fuse, having a friend helps. This way the ECM can't know anything except that the battery was disconnected, and the fuses will know where they came from. Cycling those connections also helps keep old connections healthy.
Good luck & let us know how it went.
Remember were attempting to discover any unexpected parallel loading across the (+) & (-) wires, not bad or intermittent series connections. Those won't draw down a battery. They simply don't deliver voltage well when turned on & energized.
