Where can i find 4 inch flared fiber glass fenders
Leviking.1693
i have a 1985 ford ranger that im trying to find 4 inch flared fiberglass ford i cant find it help
thanks do u know anything about swapping i beams to give more witdh or cutting and bending the i bems.... is there any way i can just extend the stock i beam
I have run across threads while researching. You should do a search using the term/s;
cut and turn
c and t
long travel tib
lt tib
After searching on TRS you can also look on desert rangers, pirate4x4 and search for other forums that are into that type of racing and pre-running.
