What's this??
your doing an excellent job and i wish i had half the fabrication skills/tooling u have, i indeed am looking to do a turbo project on a 3.3 in the future and i like the way your setup looks. my turbo will be mounted in a similar location and seeing setups installed helps my visual of what i want to do, thanks for your posts so far and keep up the good work.
I'm not posting this to get help or criticism. I'm posting this to help other gather ideas for doing a similar setup. There are a bunch of turbo guys I'm friends with that have helped me with some advise. So thanks for trying to help.
Those of us posting and commenting are doing so for constructive purposes, not to be critical. Most of the comments come from people with turbo experience, and if we can help avoid a conflict with your installation, it is a plus for you. Whether you take the advice or not is up to you, but it is there for you if you want it. But, self education can sometimes be expensive as hell.:)shady
Likely going to fire it up tonight. for a bit to make sure there are no fluid leaks.
Looking good. Good luck tonight!
I still have a bit to do. I was hopping to work on it all day but that got canned right away with a power outage. I've got my fingers crossed. Only thing that could slow things down is that my batteries are dead.
looks great get it started. Do you have a wideband to monitor the AFRs?
My brother inlaw has one that hass a sampler pipe. It will be used to tune the extra injectors. I've got the wastegate wide open right now and plan to keep it like that for the first startup. I'll start adding boost when I start tuneing it. We are in the middle of a blizzard right now and i'm not going to be tuning when it's like that outside.
That sounds badass.....When can I drop my truck off for a turbo setup?
-andrew
Oh c'mon....you know you wanna do another one! Do you have a cam etc or is the rumble stock? lol
