Rico
- Jan 4, 2009
If you are going to put a new cam in maybe you do one more thing while you got everything tore apart. Mill your cylinder heads down as much as they can without the valves hitting the pistons. This will raise your compression ratio and give you higher horsepower numbers. Just a thought since there is not a lot to do with these motors.
