The_Dealer
im trying to figure out what wire i need to splice into for key on power. i need power while engine is off but key is on, and engine on key on power. can i just splice into the red/ lt green wire i used for the duraspark box?
im trying to wire my reverse lights up and i need power going to the plug. i already know the light is the purple striped wire. im also going to be wiring an aux backup lamp in as well.
the next thing is the electric choke. when i did the duraspark conversion i foolishly cut the wire that goes to the choke. what wire can i tap into for that? can i use the same red/lt green wire as the duraspark box, or do i need to run a wire from the starter solenoid?
im removing the holley carb and putting a 2150 back on, and im trying to get my electric choke where it will work properly.
thanks guys
thanks guys
