what tool
Plasma cutter are awesome if you can bet one. other wise sawzall or cutting wheel on grinder.
angle grinder with cutoff wheel and masking tape or Reciprocating Saw
jig saw is one of the most common and gives a nice clean cut...
For metal as thin as a fender, I find a Sawzall is a noisy PITA. I've seen people (Todd) use a grinder and it is much smoother and quieter, also faster.
i use a grinder with a cutoff wheel, with the larger wheel its easier to cut through the thin metal and get the curves u need
