rfl
Dropped in a remanufactured 4.0 (directly from Ford) in a '93 Ranger. Primed the oil, fires up without hesitation (after priming fuel). Oil pressure is what I would consider excellent at all times.
Engine has a loud tick. Best I can tell it is the valve train - using the pipe method, the noise is consistent on both sides of the intake and front to back. Noise is consistent regardless of temp, and follows the RPM's.
Given this is a Ford motor and you cannot adjust the valves, I am thinking it is the oil viscosity - I put in Royal Purple break-in oil. Before I drop the oil or worse yes, start digging into the top of the engine, I am looking for some serious guidance.
FWIW, I am not proficient in Ford's by any means, however I have rebuilt engines and raced those same back when fuel injection was spraying ether in a carb, and wrench on high-end motorcycle engines regularly - point being, I do not believe I did anything wrong. This just has me stumped.
Also, nearly everything under the hood is new. Injectors are refurbished BW's.
