What should i swap too?
Tickit Master
jan 99
hello im new to the board what i have is a 99 ranger and it was made in jan of 99. ford must have decided that the engine was crap:secret: in the begining of the year so they changed it in july. the cam shaft syncro went at 120,000 miles. i replaced it and got maby 30 miles out of it and it seazed. so, where i stand is i dont want to replace it with the same crap again it is the 3.0 flex, 4x4 extended cab xlt. what bigger better engin will match with my auto trans that i had rebuilt 6 thousand miles ago?
there are no bigger better motors for your transmission. If that's your only requirement, you're stuck with a 3.0
ok so what is the easy way to swap with something that will fit including motor and trans?
An Explorer/Mountaineer 5.0 with your 99 its a bolt in swap.
computer?
if i go to that will i have to swap computers?
Go into the technical library, there is a very good, well written explaintion of just what you need and how to get it all done. Explorer EFI V-8 swap
Mac
