What rims are these?
justinae
Portland, OR
Looking to identify these rims and caps.
I was lucky enough to get two sets of rims/tires to switch out my winters. Anyone able to identify if these?
First set
215/70R14 Hankook Kinergy ST
Tread: 5-7/32 in great shape
Date: 2020
Rims: Can anyone identify these rims?
Caps: dog bowl Ranger/Bronco
Second set
215/75/15 Kumho
Tread: 7-9/32 in great shape
Date: 2023
Rims: Borlem YL24 rims with 12mm inset What model did they come off?
Caps: don't think they match. They use compression but don't seat. They just loosely rest and I don't think they compress to the nuts. Maybe it needs the same compression harness from the first set? What caps would go with these rims?
All of these rims are stock steel rims from the 90s rangers. The first set is from 89-92 rangers as the center of those caps are black. In 85-88 those were red.
The next set are also stock ranger rims from the 90s..those center caps are from 95+, possibly from the crown vic, explorer, rangers. Those weren't made for those rims, yet with the correct lug nuts they may work?
Those were on xlt rangers and explorers in the mid to late 90s.
Thanks! Mine is a 2wd so the more sedan looking rims fit it just fine (though I do think some 31s would be fun).
I'll see if those caps work once I've got them on.
the second set was factory issue on my 2005 XL. both rims & caps. the caps snap over lug nuts with wide rings.
Depending on your stock tire size the speedometer read about 7% different if I remember right.
Like said above you need the right lug nuts to get the bottom caps to fit, if you don't have them now go to the junkyard and look in the bed of Rangers... the one on Foster usually has quite the selection.
