what rear shock bolts up
not sure i bought 4'' lift shocks from sjyjacker on my rig, but heres the shackles i recommend, not much more $$ and i just installed a set, as well as installed a set in my friend chebbie, and they are holding up well, and bolted right in to my ranger!
there 2'' longer the stock roughly, youll gain any where from 1.5-2'' of actual lift... i work 12's at work, 2 on 2 0ff 2 on 3 off 3 on etc... i have tomoro and thursday off then work fri-sun
i get my u bolts in tomoro, hopefully at lleast, im gettin them custom made lol... and i should hopefully get the rear done the next two days, it will have 3'' blocks replacing the stock 2.5'' block, as well as explorer leafs and bell tech shackles... ill post a total gain with this setup, fairly cheap to do, if you have a local u-pull type deal
