what methods do you guys use for tightening outer spindle nuts
swynx
lewiston idaho
The spec is 150 lbs. I've got the tool. Half inch torque wrench. Can only get it to a little over 100. Maybe 110. Seems like I'm missing something. Try as hard as I want but Theres just not enough leverage. It slips off and I slam my fist into something
I've gotta be missing something. I can barely get it past 100 and you guys talk about 250.
Pipe buddy, pipe. Get the strongest, longest chunk of pipe u can find. Use a good tight socket. Get a guy holding the socket on the nut and a great big dude on the other side on the pipe. If u bend the pipe.... Get a bigger one!
Honestly...I just use my 1/2" impact now mostly. But I never really had any trouble with a torque wrench....I used to set mine at 220ft lbs when I still had the D35.
I have the enclosed style socket....I think it stays on a bit better than just the 4 prong.
^THIS^ and put one of your spud fed girlfriends on the end of that wrench bro.:icon_thumby:
What type of torque wrench is it, a click or the old bending type, with a scale and pointer, Iam old and pull 250lb no problem but only with a click type 1/2", pipe on a torque wrench is not a good thing, for the tool, you can rent a larger wrench at a lot of places, autozone and the likes
I have the click type. I figured it was an air tool or 2 man job. I just have the 4 prong. Which sucks. Would using lock tight help to keep them from coming undone?
I just use an extension tool for those tight to get to areas. Once you smack a knuckle you get smart....lol
I got mine to 170 with the 4 prong tool and torque wrench that's about 2 1/2 foot long
I hear ya I would get a buddy to come over and put some weight on it while you hold the socket on
There is a torque spec for those? People actually try to spec it?
I always just lean on my 1/2" breaker bar till it feels good and tight. At least for my BIIs. My F-150 has the same setup but when I was junkyard hunting for manual hubs for it I found some aftermarket ratcheting nuts. Instead of two little nuts, it's one nut with a ratcheting hub, just spin it on and crank it down. Wish I could find a set of those for the BIIs.....
Saw a set of those in disciples b2 build thread. Any one ever try to locate a proper size nut/bolt I know I could get way more leverage with a deep well socket
I use a INCH POUND torque wrench on mine, after you torque it, you must loosen and torque again, got to get a good reading with all the grease you've packed in the bearings. 2wd BTW.
If u don't buy crap tools ur fine..
