Ranger Kip
- May 2, 2010
- Wellsboro, PA
- Automatic
- My credo
- Confused and Intolerant
Does first generation Rangers have ABS or TCS?
RABS started in 86 (at least that's the earliest I've seen a light in the cluster for it). Modern TCS wouldn't be around until the early part of this century. TCS relies heavily on computer controlled stuff, so your truck WON'T have it.
Don't worry about RABS, it causes more problems than it helps solve anyway.
Your back already?
do I want limited slip?
HECK, what is slip?
And what does the decimal for the axle type mean? like DANA 8.8 or whatever, I am clueless to anything axle related.
Limited slip does in the axle what the name implies. A regular differential transfers power to the side of the axle with least resistance (least traction normally). A limited slip helps distribute the power to both sides of the axle (so both tires can drive the vehicle) so more traction can be obtained and limit the amount of tire slipping. (this was just a brief explanation, you'll want to do some real research in the tech section to understand differentials.)
What does the axle code say on the door tag?
