5w-30 is the exact same viscosity as 10w-30 when the engine is at operating temperature.
yup, and the 2.9 likes to really tick when its cold, and the thicker oil helps with that....thus the point
Thick oil and cold weather? Sir that does not add up. Also stated in another post of yours. "your a fool if you run syn in a 2.9" I think you might offened people with that statement... It's your choice to run whatever you like in your truck but don't state that someone is a fool for using something other then what you use. On another note you say you buy whatever is cheaper? You know it's not wise to change brands of oil. You pick a brand and stick with it.
His ideas behind that statement are mostly sound actually.
Shitty oiling design, bad cam bearings, and the like prove it sound to a degree.
Lightly worn cam bearings are what cause the lifter tick and eventual knock in a 2.9L. Thicker oil is the only cure no mater the time of year for this problem. Thinner oil will work at start up but once your at operating temperature its useless in a 2.9L with any mileage on it. I know it sound sass backwards but its true. I've had three of the turds and they all suffered from the same problem and the only thing that temporarily cured the impending failure was thicker oil in all three cases. I'm not saying run 20W50 in the winter time but a little thicker oil is definitely the key with a 2.9L IMO.
The reason for the synthetic is this: Have you ever seen the inside of a 2.9L running conventional (dino) oil? There is, almost always, a good thick layer of black sludge coating everything. My hope is that the synthetic will not deposit that junk on everything, instead holding it in suspension until it gets to the oil filter.
Ok, so switch to something like a 0w40 or 5w50. They're both made by popular synthetic oil manufacturers. That way it'll be light enough at start up, but thick enough at operating temperature to prevent the lifter tick.
OBTW: http://www.bobistheoilguy.com/cms/index.php?option=com_content&view=article&id=83
If you look at my other thread, I'm now running 0w20 synthetic in mine.
