What did YOU do today?
I have a little knowledge on working with acid. Never used it on metal but I’ve used it on concrete a bunch, lol. I don’t remember offhand how much baking soda we would use for a wash but it was a lot. We would slop it on the concrete, scrub it around a little, then rinse it off. Concrete being somewhat porous is probably a lot of why three washes or more is needed, but I have a suspicion that one wash may not be enough and agitation/scrubbing may be required.
Gotcha.
Ill just buy like.. 10lbs of baking soda next time I have the time & the weather is conducive to painting outside and add just enough water so it's essentially a thick slurry to soak everything in after another acid bath.. Scrub everything up real good.. hope for the best 🤷🏻‍♀️
Gotcha.
I don’t think I’d go to the slurry point, you probably used enough baking soda, but I think I’d do a soak/scrub, rinse, then another soak/scrub in a fresh batch of baking soda and water and a final rinse.
More grass cutting and more metal fabrication.
work,work,work. but its the weekend and ironically that just means more work -thats co$ts me rather than pay$ me. Truck has quite a bit of treated lumber in it, for 3 separate projects, have a seat to change out after I (try) to clean it up some, may end up just vaccuming it after a baking soda treatment & then a seat cover. The original seat is in way worse condition, I put a seat cover on it but it doesn’t fit right & just hides the horrible condition its in. Not sure if I ever posted pictures of the seat or not, odd for a 90K truck to have a seat so bad, the replacement seat came out of a 94 F250 with 140K. its sat for about 15 years now, im surprised mice didn’t tear it up, they did set up shop in the glove box though. Any thoughts on what to try on my replacement seat that wont damage the fabric? There was mouse evidence on the seat but since being in my garage I dont smell anything, that could change of course once its back in a confined space. Heres some pictures, the ‘94 seat was red once upon a time.
Gotcha.
And baking soda is good for your homemade electrolysis tank. A swimming pool and a 300 amp welding power source can do wonders! (No joke, someone did this for a frame off resto).
Worked on completing a little outhouse to store gardening tools and fertilizer, etc in. Got the tin on the sides and the roof today but it still needs some tin corner trim. I cut and "milled" some telephone poles to use for runners underneath it but I'll have to attach those later this week. After that I need to fit up the front door from my grandpas old house. A 150+ year old door.
Where I, and my family, come from that isn't what is stored in an outhouse... My dad had a great aunt in West Virginia that finally gave in and got a kitchen sink but never had any other indoor plumbing.
They are cuter then a 2.3
I usually ignore online errors anymore, but since that sentence more or less works either way I can't decide if you used the wrong "then" or if you left out a comma.
I had good luck with this stuff that was pretty cheap at Wal-Mart. I didn't noticeably have mice on/in my seats, but I had dirt, grease, and a lot of cigarette smoke in them. Thankfully my mice had pretty much stuck to the floors and inside the body behind the passenger rear seat. In fact, I found a desiccated pair in a nest on top of a can of tuna that expired in 2012 under the spare tire jack holder. I still have a bit of a smell when it sits in the sun with the windows up but it's a lot better than it was. I'm also not certain the smell is coming from the seats. https://www.turtlewax.com/products/...rpose-cleaner-car-seat-stain-remover-18-fl-oz
Here's a before and after of my driver's seat with one good cleaning using that stuff. The weird clean strip at the front of the dirty seat picture is where I was experimenting with dish soap, borax, and a lot more elbow grease than the spray required. The can says to let it dry, but my seats were so dirty that I had to wipe the foam off to keep the brown from redepositing. I've used it another time or two since this picture and gotten my seats cleaner still. In total I've used almost two cans just on the seats and seat belts.
Great success with the bike today.
Cleaned the carb & re-jetted it. Once the bowl was full it fired right up.. idle gets a little Shakey after a few seconds and it'll eventually stall but I didn't tighten the intake boot around the carb so it may just be having a little vacuum leak (wanted to get a test ride in before it started pouring) Runs MUCH stronger now either way.. from a 38 to a 40 idle jet and 95 to a 100 main.. new needle clip setting one notch higher than stock.. she'll juuuuust about yank the front wheel with an enthusiastic twist of the throttle in first gear now without the need for any additional body english 👍🏻
Yessah bub.
Totally bungled up trying to remove the mixture screw though.. it was hidden behind a plug which needed drilling out.. that was easy.. but then they're ALSO surrounded by epoxy AND apparently have thread locker on them so 🙄 it probably ain't ever coming out of there now without some real careful drilling.. no big deal. She's plenty responsive just off idle so.. probably don't need to mess with it anyways.
Regular tune up stuff is next along with swiss-cheesing the air box, then new wheels&tires, then a new exhaust...
All said and done (for this year anyways) I'll only have about 1100 bucks into the thing.. 600$ for new wheels/tires/tubes, 400$ for a stainless full system, jet/needle kit was 50, and the tune up stuff will be about 50.
Not bad for a bike that's still worth north of $3000 🤷🏻‍♀️
I can replace the plastics, seat cover, bars & riser, grips, pegs, and the rest of the levers next year and still be able to make a profit if I wanted to sell it 👍🏻
I won't though lol.... This is the first dirt bike I've had in a decade and it's gonna be the nicest one I've ever had once I'm done with it for this year. The last bike I had was a 2000 kx80.. the trans leaked so bad around the counter shaft on that bike that It needed to be filled with gear oil literally every ride... Kept the chain nice and lubed though!
View attachment 143746View attachment 143747View attachment 143748View attachment 143749
Im still jealous you snagged that thing lol
Mowed, finally ran the string trimmer, tried to burn a brush pile. Set everything except the brush on fire. (Seriously yard, gas jug, and myself.) It's all fine except the gas jug. Then went to dinner with Mom. (Pizza and salad buffet). Then came home and cleaned truck out and packed for a ride tomorrow.
That’s why you use a gas/used motor oil mix or diesel/kerosene for a “liquid boyscout”
I had a half gallon of charcoal grill starter fluid that wasn't working. The 5 gallon gas jug was on the back of the truck 20 ft away. It was stupid I know. Stiil wondering what it's gonna take to burn these damn limbs. Maybe some thermite would get them started? LOL
The flashpoint on charcoal fluid, white gas, regular gas, etc; well, it’s just too high. It’s dangerous rather than good for getting something burning. You need a heavier oil to get a bonfire going. Something that doesn’t flash off. Or build the burn pile to actually light off on it’s own.
Of course, thermite could be effective. It would bore a hole in the pile and anything else
So a good use for old oil from previous changes? I figured the black smoke would attract unwanted attention. Technically even the cardboard is illegal to burn here. Local wood only.
Green wood smokes too until it gets hot enough. Some of the burn laws are a tad ridiculous. Around here we can’t burn on Sunday and we have to have a burn permit for anything other than a “cooking fire”
