What did YOU do today?
I’m starting to get into Craigslist/marketplace a little….
I got these for the upcoming converter dolly, car trailer project, and one other. But I got such a deal, I’m thinking of flipping them. Can’t beat the price.
$20 - Does anybody recognize what jeep this might be from? He said he was told a “two door model Jeep.” I don’t know if that would be a Cherokee or a Jeep Jeep or ???
That’s a 2-5/16” ball. I’ll have to cut it off with a cut off wheel if I can’t get a key. I might flip it if I can figure out what it fits.
And I picked up these two for $30 total and he threw in six new dirty 5/8 x 8 grounding rods. I’ll sell them for $60-70, more than I paid for everything.
The top one is a Draw-Tite 41532 for 1999-2004 Ford F-250 and F-350 trucks.
I’ll probably flip that. It should go quick for $100 around here. That pays for more parts for the fabrication.
The bottom one is super heavy duty, twice the strength of the Draw-Tite. That one might also be worth flipping instead of cutting up if I can figure out what it fits.
& I’ll keep trolling until I get ready to build…
View attachment 140954View attachment 140955View attachment 140956
So, those hitch locks are usually pretty cheaply made, usually take a 4-pin key, usually pretty easy to pick, unless they are clogged up with road crud, then even a key won’t open them half the time.
one can never have too many C clamps.
welded cross bars on the lathe stands.
Looks like the “monkey bars” that were in the city park when I was a kid, back when you could have fun without the lawyers getting everybody to sue each other…
35 would feel so low. here in south texas, the average i saw, depending on how close to the tower, of course, was 60-65. guys close to the towers had to get pressure reducers added to the house inlet or their toilets valves would keep breaking because the close houses generally saw 80-110psi.
my house reads 60 at the shed and garage level spigots, i never check the upstairs because you can feel how low it is compared to downstairs.
a plumber came and did a pressure test on the supply and sewer side last week for the builder of our new house. he stupidly pumped the lines up to 100psi and blew out the toilet valve in the shed. since i was at work, i didn't know till got home and was wondering why the toilet was running out there. the builder called and told me how impressed the plumber was that the system held so much pressure and no leaks on the supply lines.
i told him nothing should leak because i redid all the upstairs lines last rummer rerouting where we had all the stuff in the kitchen and also how i had to redo alot of the sewer lines at the city side of the yard since they never glue anything.
but i hadn't found the toilet till later so i didn't get to tell him how that flush valve leaks now.
When we bought the house my mother lives in, had to re do most the plumbing. House was empty for a while. Pipe was mix of copper, black, and clear vinyl tubing?. When I turned the water on, the Vinyl and the black both burst. Replace everything with copper, good to go.
Turn the water heater on, the over pressure valve is leaking, strange. Put a new one in, still leaking. Had a pumper come and check the pressure to the house and it was around 150psi, something like that. Guy put a pressure regulator in for cheaper then I could order one online.
Explains the issues with the exploding pipes.
Cc: @superj
I’m creeping up on 71 years on this earth, and we’ve owned and managed an awful a lot of real estate, and I never heard of a house or a building in general that didn’t have a pressure regulating valve on the incoming water line. Having said that, I’ve always lived in the city/organized suburbs. Obviously, things might be different in the outlining areas where there might only be limited state plumbing codes.
My beef is with the water-saving stuff. I’d much rather have a decent flow at a lower pressure than a pressure washer, but that’s me.
Cc: @superj
I’m creeping up on 71 years on this earth, and we’ve owned and managed an awful a lot of real estate, and I never heard of a house or a building in general that didn’t have a pressure regulating valve on the incoming water line. Having said that, I’ve always lived in the city/organize suburbs. Obviously, things might be different in the outlining areas where there might only be limited state plumbing codes.
A lot of the houses around here don’t have pressure regulating valves. Just a water meter and that’s it. My parents old house was on top of a hill and had stupid high water pressure. Only problem we had was about every 7 years the hot water tank would blow out. Get out away from the suburbs here and most people are on wells.
you can put a pipe on the locking pin and snap the head off. thats what robers do to steal trailers people leave on their trucks at hotels and stuff. just a long piece of pipe that fits over it and push.
and that looks like a yj/tj factory hitch. most people give them away after trying to sell them for 50 bucks for a few months. i use them to put a reciever on my riding lawn mower
Back to work on a bathroom. Sneak peek of what’s to come. Tile may be down tomorrow. Trim is not pictured.
Yesterday, but grocery shopping then came home and hand washed Brittney's vehicles, the motorcycle, and took a soap water broom to the four wheeler that hasn't moved in 2 years. If it warms up enough today I might go try get it running.
Looking at pictures of my 94 and the super vulcan I designed and built. I miss that ranger ALOT. Buddy my second 140lb german Rottweiler. Memories..
  • What did YOU do today?
Got the fourwheeler running. Damnedest thing. It'll fire up hot or cold no choke, IF you touch the throttle. (Not push just take the slack out of the throttle cable.) Sounds rich right? If it will idle it's high and has hanging throttle. Sound lean. Also when it does idle it's noticeably lean to the point it builds heat fast. Carb is clean except maybe needle jet. I can't get it out. It's weird has a slot on the bottom like it's threaded. Turning it does nothing. Maybe a press fit? 98 Suzuki LT-F250.
The Ranger's grill didn't go to plan either. I've not found a way to remove the pieces of chrome still on it. Supposedly heat is the way to go. I used a heat gun on it till the plastic got soft. Didn't help lift that foil at all. I'm thinking I may have to sand through it. If that's all that works it'll take months of sanding for hours every day. Boss said muriatic acid. Be awfully hard to dip the whole grill.
The chrome on my 87 grill is peeling off all by itself. I have a replacement, but I haven’t gotten around to modifying it for my Lincoln grill.
It’s like a very stiff tinfoil. When you pull on the edge, it doesn’t tear, but it will peel off the plastic. My point is, maybe use a pic or a razor knife and see if you can get under the edge where you can’t see it if it gets scratched, and see if you can start peeling it up. When I’ve done this before, I grabbed the edge with a pretty good pair of needle nose. And then you probably know, but depending on which direction you pull it, you can peel off bigger and bigger pieces.
Hope it helps
Hope it helps
The pieces I have left don't really peel. I did consider taking a cheap razor and just shaving it.
You may want to Google and research how you chrome plate plastic. I believe they mold the plastic with conductive material embedded, and then it’s plated just like a piece of steel. I know you can do that, but I’m not sure if that’s how these things are made. I do know that the chrome you see is actually metal, not a paint or coating. If you can find out how it was put on, it might give you an idea on how you can take it off.
