Now I need to check my stuff. I vaguely remember taking the new one off the 2.9 when I bought the truck. It would explain some things...
I never could figure out why it had some quirks, now I know, lol. Much, much smoother throttle response now.
So yesterday I had the Choptop out, chiropractor then up to a family friend’s place to look over his Explorer he is having issues with and to swipe a hub off my 92 for the Choptop so 4x4 works. Turns out his Explorer needs a bit of freshening up, he’s got a few oil and coolant leaks.
After digging out the 92 and swapping hubs we took the Choptop for some fun in the field which ended with a small mishap and using Tom’s Explorer to help my Choptop out of the predicament I ended up in. Minor damage, not the end of the world. I pulled the bent spare tire handle out before taking a pic.
HELP!!
87 Ranger radio/cassette wiring diagram (wire colors) please and thanks!
I swapped my front fender-mounted brake light indicators last week, and after I went 5 miles, left went dark. Bad ground, I fixed that.
Then I tackled the illumination behind the gauges. Bulb dead, I fixed that. Now the brake indicator, that was working, isn’t working, but I’ll get to that tomorrow. From baking in the sun for 40 years, all that plastic stuff is as brittle as a potato chip.
View attachment 139095View attachment 139097
Then, with the radio working fine, I not-so-wisely said “Gee, I bought those belts for the cassette player a while ago. While the dash is open, let me fix that!“. Yeah, I screwed myself.
I took the radio/cassette out no problem. After I took the slide catch off, and I took the bottom and top covers off, I realized I had to take the face plate out to get to a screw holding the cassette part in place. Well, I don’t know if it was poor design, or it was just 40 years sitting in the sun, but there’s a ribbon 20 circuit connector between the radio and the face plate that’s about 3/4 of an inch long, that’s held on with the breath from a small baby. When I took the face plate down, it pulled loose. There was a clear plastic holder on top of it, and I hoped that if I put it all back in place correctly, it might work. No such luck. Oh, and by the way, there was nothing wrong with the belt on the cassette player, but now the whole thing is toast. And, the sun was going down, and it was getting colder (for Atlanta), and I had a date to watch a movie.
Before I quit, I dug out two spare Lincoln radio/cassettes that look almost identical. One was from an 88 town car and one was from an 89 town car (I thought). I wrote down the part numbers, and I wrote down the colors of the wires.
After I got back from the movie date, I tried to look up (1) the wiring code for the 87 Ranger, and I couldn’t find anything that seemed to match what I’ve got (all original wires in my truck). The part number on the radio was obliterated from age.
FYI, when I grab something like a radio or anything else electronic from the scrapyard, I try to cut the cables and save the cable end, so I’ve got something to splice to if I need it. I used the part numbers from the two Lincoln radios to look up their wiring diagram/color codes.
I found the (2) 88 radio, and none of the colors matched the colors that are on the actual radio I have. When I googled the (3) 89 radio, it said it was from my Mark VII, but then the description said it was from an 88 or 89 Lincoln premium sound system. Both by 88 and my 87 Lincoln TCs have the premium sound systems which also have an amplifier independent of the radio, but they’ll slide right in to where the Ranger radio sits.
Long story short, none of the wiring diagram information from any of these matches web to actual, what’s actually on the radios. I looked all over the place, including The Ranger Station, and I couldn’t find a wiring diagram (diagram or the color codes). I found later models, but not the 87.
Can somebody direct me to the 87 wiring diagram and colors? I’m not afraid of splicing the wires if I can figure out which is which on either Lincoln radio, and what the 87 Ranger radio put out.
I don’t need any help going forward and leaving stuff alone if it ain’t broken. I can listen to cassettes at home. I can even listen to eight tracks at home. But I can’t drive a truck without a dashboard!
All help graciously appreciate appreciated
from an'87 Taurus book, radios look similar.
Thanks. It still seems everything I look at in that 86 to 89 time frame has totally different color codes, which is doubly annoying when everything you read says the color coat on everything was always the same for Ford. I dug in the dashboard and took pictures of what’s in there now. Another problem I’m going to have is those wires all barely pull out to the face of the dashboard. It’s going to be a pain in the butt to splice them.
Both plugs are 8 pin, and they are different shape than the Lincoln plugs. I’m assuming the four wire is the input: always power, ignition power, lights on, and something else. Like also have the antenna and some other things, six and seven wires, with the eight wire speaker plug.
I’m assuming the eight wire are two wires each to the four speakers. That should be easy enough to trace down if I can’t match colors.
I’m still looking for input if anybody’s got some. Edit: I think I’m going to use saddle crimp taps so I could save the existing plugs should I ever come up with a correct radio.
HELP!!
did the ribbon connector have a small flipper that locks the ribbon in? they look like a flat piece that moves against the ribbon.
you can identify which wires go to which speakers with an ohm meter. there will be a small crackle at the speaker as the leads hit the wires, scratch them for better results.
View attachment 139123View attachment 139124View attachment 139125
So, I don’t like cutting the factory harness or using taps, I’ve had to deal with a number of damaged radio harnesses and it is one of my pet peeves. You can get adapter plugs that plug into the factory plugs and have wires pigtailed out so you can build your own adapter. Last I checked they weren’t expensive at all.
The plug with 8 wires is the speakers.
The plug with 4 wires should be constant hot, key on hot, illumination, and ground. You can probe them with a power probe or multi-meter to figure it out. I’m out of town for a couple days so you’ll have to wait if you want something more precise than that, I’m pretty sure the adapter out of my 88 is in my shop and possibly a set of adapter plugs that I’m holding onto for a future project
Replaced both taillight assemblies. The left one had been taped over five years from a foul ball at baseball practice. Then, about ten days ago, I clipped my daughters side mirror with my right taillight. So, good excuse to just replace em both.
@pjtoledo
@lil_Blue_Ford
@Curious Hound
The ribbon connector was brownish, and I didn’t count the contacts, but they were about 20. I couldn’t figure out if it was soldered down or not. There was a clear plastic “holder” that pressed it against the circuit board on the face plate. The radio side seemed soldered in.
It pulled loose from the face plate without any effort at all, I was being careful. I tried as best I could to put that ribbon back in the right place, but I could never get it exactly straight. In the process, a couple of the solder leads that were part of the ribbon started breaking off where they contact the circuit board. Considering the cassette probably doesn’t work since the belt was OK, I just gave up on it. I think I could eventually fix it, but it would be hours and hours for a radio that may not have a working cassette. And yes, there was a clear plastic holder stiff like a credit card, but maybe 1/4 as thick. It held the end of the ribbon down, and the ribbon may not have been soldered in place at all. The ribbon was way too short and stiff to turn upside down and backwards, etc. to try to put it back in place.
I got some more wire color code info online. I’m going to tackle it this morning in a couple hours after it warms up a little bit.
As far as the TRS site, I couldn’t find anything on the radios before the 90s. I’ll have some good information by the time I’m done with this that should be pasted where someone else could find it if they were looking. Who do I send that to?
@pjtoledo
@lil_Blue_Ford
@Curious Hound
That goes right to Jim.
Tightened my ignition switch, and liberally spread some dry lube in the column area. It doesn't squeak when turning left anymore. LOL
@pjtoledo
@lil_Blue_Ford
@Curious Hound
Radio update. The two Lincoln radios look very similar to the Ranger radio, and they slide in the dash perfectly. The plug with the power, ground, etc. is the same, and I plugged that in and they powered up. Then I fell off the edge of the Earth…
Both Lincoln radios are the premium sound radios that have an amplifier in the trunk in addition to the radio head. The radio head feeds the amp through a gray shielded cable. Inside the shielded cable, there are eight wires, which obviously go to the four speakers, but…
The eight wires in that shielded cable are smaller diameter than the speaker wires, and the color codes on those shielded cable wires don’t match anything I can find for speaker wires for Ford or Lincoln. The speaker wire colors from the output side of the amp don’t even match anything I can find in literature.
I also could not find a wiring diagram or color code that matched the four speakers in the Ranger. I used an old shade tree trick: I cut two pieces of wire and taped one to the top and the other to the bottom of a AA battery, and looped electrical tape lengthwise to hold them down. Then, by touching the contacts in the plug for the speakers, I could get a crackle out of the speakers, one by one, so I could identify which wires go to which speaker. That doesn’t tell me which is positive and which is negative, but I’m assuming the top of the plug is positive as that is what I saw in every one of the diagrams.
I tried the same thing with the Lincoln heads powered up, but I couldn’t get a crackle out of a speaker no matter how many combinations I used.
I probably did eight or 10 hours of this in the last couple days…
lincolnsonline.com is the Lincoln version of therangerstation.com, and they have a towncar section. I posted everything up there and told those guys what I was trying to do, so hopefully I’ll be able to find out if the Lincoln radio head can feed the speakers directly without the amp, and which wire is which from the Lincoln radio.
My Plan B is the aftermarket modern radio CD player out of the 93 donor truck that is long gone. But I really would like to have a radio that looks like it belongs in the truck, but the CD would be nice I guess.
More to follow…
The eight wires in that shielded cable are smaller diameter than the speaker wires, and the color codes on those shielded cable wires don’t match anything I can find for speaker wires for Ford or Lincoln. The speaker wire colors from the output side of the amp. Don’t even match. Anything I can find in literature.
My Plan B is the aftermarket modern radio cassette out of the 93 donor truck that is long gone. But I really would like to have a radio that looks like it belongs in the truck, but the CD would be nice I guess.
More to follow…
My understanding of the Premium Sound stuff is that if you don’t have the amp, don’t bother trying to make it work. I never messed with it although a couple of my vehicles had wiring for it. That was really weird to me to pull the radio and find that extra plug for premium sound just hanging out in the dash.
I personally often upgrade the speaker wires anyway, get some decent quality 14 gauge speaker wire and go to it.
Premium Sound has to be run through the amp, the head unit doesn’t put out enough power to drive the speakers on their own IIRC.
See how things go, sometime between now and Tuesday I’ll try to get a look at what I have for electrical on these
I always appreciate any help, thank you.
If Lincolngetsonline.com can it help, I’m probably going to finish this up today if that aftermarket radio works just so I can get the truck back on the road. Then, getting a period correct radio will be relegated to another thing on my long list….
Radio update:
I finished putting a radio in my truck, I have dash lights, and both of my fender mounted turn signal indicators are working. Already.
It only took me five days. And that’s not completely accurate. I didn’t put “a” radio in my truck, I put four radios in my truck, but finally made one of them work - the one I liked the least. And several of them I put in and out of the truck several times. I had to do that over and over just like installing the LED bulbs to light up my dashboard and my warning lights. Any job worth doing is worth doing twice. These particular jobs were worth their weight in gold. If my time is worth five dollars an hour, I could’ve bought the best brand new stereo system in the world.
Conclusively, the Lincoln radios will not work without the amp that comes with them. I’m saving them and I’ll probably pick up an amp the next time there’s a square body Towncar in the scrapyard.
When I was trying to install the Lincoln radios, I didn’t want to cut the Ranger plugs in the dashboard. When I had to install the aftermarket radio, I doubly didn’t want to cut the plugs in case I come up with a Ranger radio, or one of the Lincoln amps.
So I took the plug block off the back of the bad radio. I popped it open, and by putting a little heat on the back of the circuit board, I was able to pull the circuit board free from all the pins. Then I cut it in half, and soldered leads on all the pins on the inside side, so I basically made my own adapters.
I also realized that the wires were labeled right on the circuit board for the speakers, so that helped a lot.
Notice the one on the left has several spare pins. That was a blessing also, because I broke three of them when I was putting the radios in and out. I was able to pull them out of the black plastic and reinsert them where I had broken one. I was down to one spare when I made it all work.
Having a blue neon radio in the middle of that woodgrain vintage dash makes my skin crawl. And you can’t really read the face, the thin black font against the bright blue background But it does work pretty well. And the CD works, which is a step up.
BTW, that radio was also scavenged off “Barney,“ the purple ‘93 donor Ranger I used for the Road Ranger’s 8” bullet hole wheels, the fiberglass grill surround and the bumper, and the Missing Linc’s seats, and a bunch of other smaller parts. While it wasn’t free, I remind all that I paid $400 for Barney, stole about everything that was worth anything from it, and sold it to Pull-a-Part for $365.
The green LEDs for the dash were an afterthought, but it’s probably the first time in the five years that I’ve had the truck that I’ll be able to actually see it clearly at night!
And even though it’s been instilled in me several times before, it’s indelibly instilled in me now: “If it ain’t broke, don’t fix it.”
Actually yesterday...
Got the Ranger washed at a soft-touch car wash to get the salt off. Yesterday was the first mild day in weeks after repeated snows, ice, and temps well below freezing.
