Now I need to check my stuff. I vaguely remember taking the new one off the 2.9 when I bought the truck. It would explain some things...
I never could figure out why it had some quirks, now I know, lol. Much, much smoother throttle response now.
So yesterday I had the Choptop out, chiropractor then up to a family friend’s place to look over his Explorer he is having issues with and to swipe a hub off my 92 for the Choptop so 4x4 works. Turns out his Explorer needs a bit of freshening up, he’s got a few oil and coolant leaks.
After digging out the 92 and swapping hubs we took the Choptop for some fun in the field which ended with a small mishap and using Tom’s Explorer to help my Choptop out of the predicament I ended up in. Minor damage, not the end of the world. I pulled the bent spare tire handle out before taking a pic.
HELP!!
87 Ranger radio/cassette wiring diagram (wire colors) please and thanks!
I swapped my front fender-mounted brake light indicators last week, and after I went 5 miles, left went dark. Bad ground, I fixed that.
Then I tackled the illumination behind the gauges. Bulb dead, I fixed that. Now the brake indicator, that was working, isn’t working, but I’ll get to that tomorrow. From baking in the sun for 40 years, all that plastic stuff is as brittle as a potato chip.
View attachment 139095View attachment 139097
Then, with the radio working fine, I not-so-wisely said “Gee, I bought those belts for the cassette player a while ago. While the dash is open, let me fix that!“. Yeah, I screwed myself.
I took the radio/cassette out no problem. After I took the slide catch off, and I took the bottom and top covers off, I realized I had to take the face plate out to get to a screw holding the cassette part in place. Well, I don’t know if it was poor design, or it was just 40 years sitting in the sun, but there’s a ribbon 20 circuit connector between the radio and the face plate that’s about 3/4 of an inch long, that’s held on with the breath from a small baby. When I took the face plate down, it pulled loose. There was a clear plastic holder on top of it, and I hoped that if I put it all back in place correctly, it might work. No such luck. Oh, and by the way, there was nothing wrong with the belt on the cassette player, but now the whole thing is toast. And, the sun was going down, and it was getting colder (for Atlanta), and I had a date to watch a movie.
Before I quit, I dug out two spare Lincoln radio/cassettes that look almost identical. One was from an 88 town car and one was from an 89 town car (I thought). I wrote down the part numbers, and I wrote down the colors of the wires.
After I got back from the movie date, I tried to look up (1) the wiring code for the 87 Ranger, and I couldn’t find anything that seemed to match what I’ve got (all original wires in my truck). The part number on the radio was obliterated from age.
FYI, when I grab something like a radio or anything else electronic from the scrapyard, I try to cut the cables and save the cable end, so I’ve got something to splice to if I need it. I used the part numbers from the two Lincoln radios to look up their wiring diagram/color codes.
I found the (2) 88 radio, and none of the colors matched the colors that are on the actual radio I have. When I googled the (3) 89 radio, it said it was from my Mark VII, but then the description said it was from an 88 or 89 Lincoln premium sound system. Both by 88 and my 87 Lincoln TCs have the premium sound systems which also have an amplifier independent of the radio, but they’ll slide right in to where the Ranger radio sits.
Long story short, none of the wiring diagram information from any of these matches web to actual, what’s actually on the radios. I looked all over the place, including The Ranger Station, and I couldn’t find a wiring diagram (diagram or the color codes). I found later models, but not the 87.
Can somebody direct me to the 87 wiring diagram and colors? I’m not afraid of splicing the wires if I can figure out which is which on either Lincoln radio, and what the 87 Ranger radio put out.
I don’t need any help going forward and leaving stuff alone if it ain’t broken. I can listen to cassettes at home. I can even listen to eight tracks at home. But I can’t drive a truck without a dashboard!
All help graciously appreciate appreciated
from an'87 Taurus book, radios look similar.
Thanks. It still seems everything I look at in that 86 to 89 time frame has totally different color codes, which is doubly annoying when everything you read says the color coat on everything was always the same for Ford. I dug in the dashboard and took pictures of what’s in there now. Another problem I’m going to have is those wires all barely pull out to the face of the dashboard. It’s going to be a pain in the butt to splice them.
Both plugs are 8 pin, and they are different shape than the Lincoln plugs. I’m assuming the four wire is the input: always power, ignition power, lights on, and something else. Like also have the antenna and some other things, six and seven wires, with the eight wire speaker plug.
I’m assuming the eight wire are two wires each to the four speakers. That should be easy enough to trace down if I can’t match colors.
I’m still looking for input if anybody’s got some. Edit: I think I’m going to use saddle crimp taps so I could save the existing plugs should I ever come up with a correct radio.
HELP!!
did the ribbon connector have a small flipper that locks the ribbon in? they look like a flat piece that moves against the ribbon.
you can identify which wires go to which speakers with an ohm meter. there will be a small crackle at the speaker as the leads hit the wires, scratch them for better results.
