- May 28, 2021
- Virginia
- 4.0 V6
- Automatic
Checked the front end today.
Last week at night I heard a strange "sproing" as a pulled up to a stoplight and felt it through the brake pedal and steering wheel. Discovered later that something had scraped the left front wheel between the rim and the hub, so it was probably something metal in the road I didn't see in the dark. The tire and the plastic center cover were not damaged.
Just in case, today I jacked up the front end and pulled off both front wheels. Everything good with the brakes, all bolts there and tight. Did discover that the front bearings needed to be tweaked a little tighter after 11,000 miles on them, so I did that. Both front wheels had a tiny "click" as I pulled top-bottom, but no click when pulling side-to-side. Tightened both nuts no more than about 15 degrees clockwise, which eliminated that click, and the wheels still rolled freely.
While I had the right front wheel off, I trimmed a small amount from the large fender liner where it was rubbing the frame and had taken off the undercoating, sanded off the small amount of surface rust, and hit it with a small amount of "rust reformer" black spray paint. Rust-Oleum makes the product. I used the paint to hit a few spots on the right control arm too. I'll go back later and hit that spot on the frame with a spray-on undercoating.
Tip on bearings: you can adjust the front bearings without pulling the wheel off. Just remove the center cover and grease cap and you can get to the cotter pin, retainer, and bolt.
