OEM tube and MAF tapped to a conical filter of unknown origin.
First start. Glad there only fireworks I witnessed today were after that.
Sorry, I meant the intake manifold. What is the supercharger sitting on?
Did this a couple of days ago. Had a day off and the lettering was sitting here so I got it done just in time for the 4th?
It's the ModdBox kit. The SC sits on a two piece lower plenum. You bolt the SC to the upper half and then bolt that assembly to the lower half that's been bolted to the heads.
Couldn't wait any longer. Had to put the new wheels and tires on the Ranger. Now It really needs the lowering kit to arrive. 245/45-18 front and 275/40-18 rear. Same diameter 26.7 so no issues with RSC or Traction control.
Nice !!! I had the same wheels on my '13 Mustang GT .
The U-joints I ordered showed up early so the patio got cleaned off so I could do them. This is at the bottom of a dirt driveway with a water bar ( white rocks ) right next to it so when the water is to much the patio gets flooded and muddy, hence the shovel to clean it off. I guess I don't have an excuse to put off the other work anymore...
They got done but not with out a mistake or two in the process. I marked the shaft pieces but still managed to not pay attention while installing the U-joints .
Yup marked them with white paint.
But still managed this one. I flipped it around to double check I had lined them up for the carrier end but I saw this:
Well Now! I felt like a monkeys butt for that one. I had already taken the clips back out before taking the pic.
OK feeling like an apprentice again I lined them up properly:
This was not the last time I started putting it back together not lining up the marks. Putting in the rear section on the drive shaft at the carrier I just put one strap on and spun the shaft and saw the marks were not lined up properly again. OK I must be a gluten for stupid moments because I needed to spin it 180° and line the marks up. I did the rear end fine... It only took me screwing up the same way twice to learn. :icon_rofl:
At least the trucks come with a built in work bench:
On a Tech note, I found that a 32mm Hub nut socket fits the inner part of the Carrier bearing race to drive it on quite nicely. It drives on the metal not the rubber seal to allow for that press on necessity, though not much force was really needed to get it into position.
It seemed weird to drive the truck without that noise being there, almost like it was just part of the truck. The carrier was starting to go when I purchased the truck 3 years a go, I didn't know this at the time, and I only have put on 12K since owning it. On another note, what I had been thinking was clutch chatter has disappeared. No more shaking when letting the clutch out But this thing has done this off and on since I got it so time will tell if it was just the carrier and rear U-joints acting up.
EDIT: Dana Spicer U-Joints were in it, that is what they got replaced with, non greasable so I don't have to get under the rear of the truck every oil change. getting down once to put the jack under and to slide in is enough for my lazy rear end.
Plugged it into shore power, turned a few lights on, turned the radio on and cleaned out the icebox.
turn on the propane and light the stove...
Made it to Texas last night. The last 100 miles were rough. The 2019 did a good job and got the mileage it was supposed to.
About 24 mpg with E10 for two tanks and 25 mpg with a tank of straight gas I stumbled upon on the trip. Everything was less than what we pay back home in Taxylvainia.
Here in Kalifornika a pack smokes is $10+ bucks, same for a typical drive thru combo meal (after taxes). and 87 fuel $3+ bucks a gallon.
I installed an aooga horn. Will post pics if I'm not banned for this...
Getting ready to put on new shocks. PB blasted all the nuts/bolts. Loosened all 4 rear bolts. I was surprised at how easy they came loose. It's a 94 and I'm sure they are the original shocks.
Gross... why would you show a picture of that.
Meh... You should have seen the 2012 F450 I did front brakes on the other day. It makes that look mint.
I'm gonna throw up... fluid film and power washers exist! There's no excuse for that!
