What did you do to your 2019 and up Ranger today?
I picked up some used f150 raptor tow hooks for 40 bucks because they look almost identical to the ranger tow hooks. We will find out when we get back from our road trip. If they dont fit, they will go on my son's 23 f150
They fit!
(With some grinding)
And the pics are listed backwards
Nothing. Absolutely nothing. Got it back from the body shop almost a month ago and still haven't washed it.
Which might be a record. Been raining every day or every other day so there's no point.
Finally getting a few days without rain so I washed it, cleaned the wheels, and rubbed it out with a clay bar. Starting spring cleaning for show season. Burned a fine La Gloria Cubana while I was at it.
Just an FYI:
Our Rangers do have a Clear Flood Mode, which is a feature that allow the oil filter to be primed after an oil change, without the engine ignition firing and without the fuel injectors firing. The engine will crank, but will not start.
Hold the accelerator all the way to the floor. Turn key for 3-5 seconds. The engine will crank but not start.
Done.
CMOS
I'm in the process of setting the 2019 up for over landing. The cap came off yesterday and the Softopper and canvas over cage got installed today. The cart holding the RTT is in the garage so it can be lifted to be installed on the truck tomorrow.
I got the RTT installed yesterday as well as the mounting brackets for the awnings. The plan for today is the roof rack and the awnings. We'll see if reality matches with what the plan is.
I got all the exterior gear and most of the gear that doesn't go in the drawers on and in the 2019 yesterday. If all goes quick enough with the rest, I can give the truck a quick wash. It needs it. Thursday will be packing clothing and grocery shopping since I want to head straight to Carlise right after work on Friday.
I was gonna text you but.....
You enter the Fairgrounds camping across from the hotel where I showed you (if you remember from two years ago), there is a sign, have your camping pass on your windshield or be ready to stick it on, upper left corner, I'm at the other side of the block along the tree line. There is a gravel road from the gate, you turn right and go past the trailer parking area, then left, then make a left into the grass near the portajohns or wherever you can turn. There should be one or two white enclosed trailers from the guys I camp next to. I'm normally under the last tree.
Put my TRS windshield banner on after work, now I gotta load everything up for Carlisle.
