Weighty winch
ridgerunner
Tioga County, PA
Gonna install front and rear 2" receivers and wire both up for a winch and cradle. Thing is I already have two winches I can use. One is a heavy somebeech 12,000lb Promark with synthetic line I have set up for my Dodge 2500. It's already on a cradle but again very heavy, too heavy for the lil' ranger. I also have a smallish Warn 4,000lb winch I bought for the rear of my UTV just never installed it. I plan on buying an 8,000lb winch once the other mods I have planned for the ranger are paid for and installed (that will take time). So what do U think in the mean time? Will the 4,000lb be good enough to give me that extra tug I might need until more funds become available. I won't be mega off roading yet so I'm hoping I'll be OK. Yeah I know 1.5-2 times the weight of the vehicle to size the winch and the use of a snatch block will double the pulling capacity blah, blah, blah. Here is a pic of the Warn and big SOB Promark.
12000 pound is what my ranger requires.....i am murdering my 8k winch....keep killing solonoids.
of course my fatty mcfatterton ranger weighs 6 k.
If you don't totally bury yourself, the small winch, double wrapped will get you out (slowly), if your down to the door handles, all bets are off.
If it was me then I would use the 12k just because when it comes to gettin unstuck waiting for someone to get you I would rather have the tool on hand, but that's my opinion. I would keep the little one for around the house stuff.
The only real problem with a hitch receiver mounted winch is you have to be able to get the winch into place AFTER your ass is stuck. Often a less-than ideal thing to have to do, often entirely impossible.
I would stick the 12000 on the front of the Ranger permanently(at least until you get your 8000) and mount the 4000 on a receiver for the back.
usually in those cases i use chain.
i had to do this many times over the years to use my winches on other trucks because of the crazy situations that made that the most workable solution.
Not going to do any major offroading until I get a lift, lockers, tires and regear so I'm just hoping to get by until the funds are available to do what I want with a new winch. Anyway the 12,000lb winch has to stay with the 2500 cuz that thing is a real heavy beeoch to get unstuck! The 12,000lb on the cradle is about all I can pick up and carry too.
Now U got me thinking of putting the new 8-9,000lb on up front and carrying the 4,000lb on a cradle for the back in case I need to go backwards.
Hmmmm...still don't know what to do just yet. I'll probly wire up the rear and go out and give the 4,000lb winch a try to see just how much it will or will not pull. When I do that I'll post back on here on how it went. May be a few weeks anyway.
