dashhho
My floor carpet is wet behind the passenger seat where the jump seat is. I am thinking water is getting past the door weather stripping, is there any other ways this can happen?
Rear window. You need to unbolt it with a 9mm ratchet wrench, clean and reseal it with 1/4" butyl rope, or you can use 5/16" and smash it down with your fingers.
Last I checked you could buy replacement gaskets for the third brake light, think there used to be a silicone replacement seal for those…Makes sense Franklin. The foam gasket in the 3rd brake light is completely flat and not sealing. I think I will try and find a foam similar thickness and make my own gasket.
