- Mar 8, 2008
- Age
- 62
try it, it just anoys me when people are so closed minded that they wont try anything. minor hills and flat, yes it does work. i had improved my milage in my contour by about 3 mpg. "duaghter totaled that car"
it is a proven fact.
your turn bean, tell them all that unless they measure the grade with a laser level it wont work unless its 0.0 degrees. "or you are driving on a totally flat road" lol
Test #3 Use Cruise Control
Result: Surprisingly effective way to save gas
Cold Hard Facts: Up to 14-percent savings, average savings of 7 percent
Recommendation: If you've got it, use it.
Using cruise control is a bit of gas-saving advice frequently on tips lists. We have always agreed with this tip in theory but we hadn't expected such significant results. First, it smoothes out the driver's accelerator input by preventing nervous "surging." Second, it makes the driver take the long view of the road rather than reacting to every change in the traffic around them.
Method: We did this test twice with four different cars each time driving the 55-mile loop. The first time we set cruise control to 70 mph. The second time, with the cruise control off, we varied our speed between 65 mph and 75 mph. We tried to mimic the driving style of a person who is in moderate freeway traffic.
i think i already said this part.One thing that's important to note: if you are in a mountainous area you should turn off cruise. It will try to keep you up to the speed you've set and will use a lot of extra gas downshifting to lower gears to accomplish this.
