- Mar 14, 2008
- Age
- 35
- Pullman, MI
Haha... Ok... Whatever you say
Actually an E-fan uses more energy than a mechanical fan... It increases load because it uses more electricity, therefore making your alternator work more, and you lose energy transforming the mechanical energy to electricity and back to mechanical energy... A mechanical fan is much more energy efficient... There was an article I read somewhere that at highway speeds your A/C uses less gas than opening your windows...
an e-fan will not use more energy and make your alternator over work. the alternator isnt affected by how much electricity you are using it gives a canstant amount of voltage compared to what rpm you are at. so e-fan will take what it can get when it needs it an you will gain voltage back at a normal rate. also the ac does help as when you open your windows down the highway you get that drag of 70+ mph wind going in your windows and pushing on the inside of the rear window
