- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
its pretty simple to align these trucks a tech would have to be either stupid or in a hurry/lazy to not do at least a decent job.
You apparently don't have a clue how common this is.
A buddy of mine came to me after trying to get his truck aligned 5 (that's FIVE) times by such so called "professionals" and by this time half the tread had already been burned off his front tires in barely 5000 miles. Not a single one of them had a damned clue what to do.
After fixing problems with his steering (and switching his fawked front tires with the rears), I then aligned it using my $10 tape measure, a homemade telescoping rod, (both for checking toe) a small carpenter's level (to check camber, which is fairly easy to do by eyeball as well), and a steel plate & some metal dowels put under the tires (to eliminate any suspension bind between the front tires).
Took it around the block, it pulled to the right a bit. Gave it another half-degree caster on that side, now it tracks straight as an arrow when you let go of the wheel.
Then 3 other times I've had to fix problems with pulling to one side because 'tards (again) can't figure out how to put the proper bushings in to set BOTH camber AND caster properly (often accompanied by some shpeil about oh how "we spent all this time trying to get it as best that we could" and "that's normal for TTB", yet all they ever did was twiddle around the bushing that was already in there, never bothering to switch it with one that was correct).
A $100,000 computerized alignment machine is only as good as the idiot using it.
I've been doing my own alignments on all my vehicles for 18 years, and would have no qualms whatsoever taking a 3000 mile trip up & down the coast on a brand new $800 set of tires. I have never once had a set of tires not make it at least 25,000 miles before reaching 50% treadwear (evenly worn, too).
As long as you have some understanding of each parameter involved, it most certainly is possible to perform an exceptionally good alignment at home using plain, simple tools (it's not rocket science, really).
