majoestic
- Dec 10, 2008
- Automatic
getting code 29 telling me something going on with the VSS will this make my truck run good for a few minutes then bog down and die? if i floor it sounds like its getting no air no spark or fuel not sure but i put new fuel filter and pumps /tps/TFI/temp sensor and only code i get is 29 could this little sensor on the tranny be causeing me this problem? also if i unplug the negative terminal and unplug the sensors listed above and reconnect every thing it will run a few more miles and start acting up again any ideas?
