saltydriver89
The truck: 1999 ford ranger 4.0l (pushrod) 4x4
I got back home after a 20 minute drive around town and noticed a vibration in the steering wheel as I pulled into the garage. It went away in every gear except OD. I turned it off and let the truck sit for about 20-30 minutes. When I came back, the OD gear vibration was gone. I drove it around the block (<5 minutes) and it returned. I was looking under the hood and noticed that the steering column boot was torn. I also noticed that one of the recently (within the month) replaced upper control arm (greasable) ball joint boots seemed to be leaking. I should also mention that the since the front end suspension was completed, there has been a sound (maybe knocking) coming from what seemed to be the CV boot/joint. The boot looked like it may have been leaking, but during the front end replacement there was a P/S fluid leak due to the steering knuckle having shifted too much while the engine was off so I'm not positive. I'm concerned I cannot use this for a DD until these problems are resolved.
Any help would be awesome.
